Technical No air con?
Re the aircon would you service it now or wait for spring?
The aircon gas also contains some special oil, that circulates when the system is running. This oil lubricates the pump, but importantly, also keeps the seals, in the pump and at each pipe joint, supple. Without the oil, the seals shrink, allowing the gas out.
The longer it is left without gas, the more likely it is that the seals will fail. Whilst seals are cheap, the labour is not, as they are fiddly to fit. A new pump is around £200, or more, plus fitting.
Of course, you have no idea how long it has been out of action. Most garages now service aircon. They can evacuate the system, and apply a vacuum, and see if it holds. If it won't hold, there is an obvious leak. At that point, you can just leave it, never to work again, and cook in the little greenhouse in the summer, or the next stage is to pressurise it with nitrogen and search for the leak. Once found, a quote for repair will be forthcoming. Of course, after any such leak is fixed, it could still need a pump.
If you switch the engine on with the A/C off
Look at the center of the compressor pulley it should be stationary
Have someone push the A,/C on the light should come on and the center of the compressor starts turning
Like this, not a Panda but very similar
If it does, there must be still some pressure in the system, and probably worth a shot at a re-gas
There is a safety feature, no pressure, no engagement
I use the Aircon more in winter than summer, it almost instantly demists the windscreen
Unlikely but If you have access to a scan tool that can access the body module the pressure can be read directly
I not 100% sure if the light comes on or not if there's no pressure, most cars don't and yours does so it's worth looking for the clutch engagement as in the video as a quick next step
Same, it's unlikely to just need a re-gas
If fairly common for the condenser to leak as it subject to years of stones and salt,
But without the right equipment we can only guess
A mobile Aircon guy will check it out and give you a quote,
It's variable depending who you get but someone did get a condenser fitted and a re-gas for under £255 about a year ago
Given how much I'll be using the car it's not worth spending that much on it.
I can ask at the garage next week though, they might do a free investigation.
Neither would I; paying a quarter of what the car cost to fix something you don't need isn't what low cost motoring is all about.
And if the compressor is toast, it'll cost you close to what you paid for the car!
I have a friend with a Volvo that lunched its compressor at around four years old; despite the car being worth well into five figures at the time, he decided that spending the best part of £1500 just to have A/C working again wasn't worth it.
It's still an improvement on the first few cars I owned; on those, you had to wind a handle to get fresh air into the car; on the Panda, you can just press a couple of buttons on the centre console!
Happy motoring with your new car.
It's still an improvement on the first few cars I owned; on those, you had to wind a handle to get fresh air into the car; on the Panda, you can just press a couple of buttons on the centre console.
To be honest I'm not feeling that way at the moment. My first car was great until the underneath was eventually corroded beyond repair, and the second (same Susuki model but newer) was even better until corrosion and repair costs finally got the better of that too.
I'm hoping the initial issues with my Panda are either simple repairs or just the differences between brands and I'll eventually get used to them, although I think I'm stuck with what I'm sad to say are the worst pedals I've ever used. Still, early days yet.
I'm sorry to hear you're disappointed with your purchase.
The pedal position has been commented on since the car launched. I got used to mine fairly quickly, but they definitely don't line up with your feet when sitting naturally. They're too close together, as well. I'm a size 9 and can imagine anyone with larger feel might struggle not to press two at once.
The self cancelling indicators that won't latch just when you need them most are another frustrating Panda feature which could have been designed better.
But apart from the A/C and the slight exhaust leak, what else do you think is wrong with it?
I often swap between two car
Panda - mercedes A class
Then later on
Panda - Suzuki Splash
There all very similar driving positions, pedals, even the clutch bit points are very similar
If I jump into or from a seat there is an adjustment period as on these cars the brake pedal is higher than the rest
Finding the seat position, is important
I'm also a size 9 and I'm finding them really close. It's taking full concentration to get my foot in exactly the right place to press the brake without also pressing the throttle, but I've learnt to keep my clutch foot far left to give me a little more room. I just wish the throttle was another inch or three to the right, and a bit lower.
There's the engine blip, which is hopefully just spark plugs or the air filter, and yesterday I started thinking the clutch is very high and it is occasionally hard to push into gear, perhaps normal or maybe a sign the plate is wearing.
When I opened the boot after rain the other day the floor was wet, I don't know if it's a leak or if it spilled in as it was opened.
Difficult to see coolant level, I overfilled and had to suck some out again.
Mirrors are very very small compared to my previous two Suzukis.
Other than those it's looking good, it's comfortable and surprisingly fast, although a bit lower than I was hoping for. The steering is very light and the ride is soft. Fingers crossed I can get it fixed up and it will do me well.
Then later on
On my Suzuki there's 4 inches between the pedals and the throttle is about half the height of the others so it feels very different. Unfortunately my Panda only has the basic seat so not much adjustment, but I'm gonna see if I can turn it if I have time over the weekend.
I'm no stranger to swapping vehicles myself, I once drove 5 completely different tractors in the same day, then drove home in my car and jumped in a Land Rover. 😀
This was fixed for the 2010 model year (my own 169 has the larger mirrors) and aroused considerable discussion at the time; not everyone was in favour of them, but I find they work well for me.
It's possible to swap them for the later type if it really bothers you.
I
I've just missed out then, doh!
I loved the mirrors on my first Suzuki, they were about a foot square, awesome things. Hopefully I'll get used to these, they're not that bad.
I've just discovered the pedals are a million times better if I wear my wellies instead of my trainers, so there's one problem sorted.
Pretty much every car is now has fairly level pedals
Swapping to a car to or from a car where they are not is awkward, but you soon readjust
I am size 12
Probably the most urgent job
It not uncommon for the rear to fill with water
Unfortunately there's not one answer
Click on the link below might help
It's not the best design, made worse if someone diluted the coolant too much with water
there are several options
Blow down a pipe,and listen for bubbles as it hits the coolant, I find this the quickest
You can see the level if look down the top
At night you can shine a bright touch against the side
