Another Forum member just sent me this , so should have plenty of power, if that model and all running good.I remember seeing 8140.47 on a plate under the bonnet, Regards, Larry
Yes, the Luton is a bit of an "air brick". If it is fairly quick of the mark pulling away, but loses it at higher speeds then aero dynamics may be the cause.OK, thanks for that info Bugsymike. The engine starts on first turn of the key, drives very well and isn't thirsty on diesel. I think the shape of the Luton body with overhead cab causes a fair amount of wind resistance which creates more noticeable drag when climbing hills. I suppose I'm comparing it's performance against a more aerodynamic car which isn't a fair comparison, Regards, LarryK
