Punto (Mk1) newbie with wiper problem
daz72
Hi all, very new to this and just signed up
Not sure if I am posting this in the correct area :cool:
I have a 97 punto and when I use the windscreen washer the wipers dont automatically work...
Is this correct or should they work? (They will work when I turn them on)
Cheers (y)
My does not work, although I changed the washer pump first thing when I got the car as it was not working. I only got the front to work. I turn the wipers on an then activate the washer. So in short most likely the washer needs to be activated manually.
Rear washer has a one way valve which is located next to the washer bottle behind the inner passenger front wheel arch they mess up preventing it from working take it out and connect a joiner to pipes and it will work them
Cheers (y)
Yes this is normal. I have a Mk1 75SX and using the windscreen washer does not automatically give a wash-wipe; you have to activate the wipers the wipers manually
