Multipla  newbie with door handle problems
colin2016
hi guys n gals, I have a 2008 multipla and drivers door handle broken so I now have to go threw passengers side door to get in :( does anyone no where I can get a new handle and how easy it would be to replace and if I cant get one would I be able to take the back door one and replace it with the front. I have tried everywhere I can think for cheapness being xmas time money is tight thx in advance, its an external door handle
Hi, and welcome,:)
normally, you have to remove the door card / trim ( like handles)
then the outer handle will have a control rod / cable linking it to the lock mechanism,
then unbolt the inner fixings at it should come away.
https://www.fiatforum.com/multipla/237290-stuck-door-handle-here-diy.html
https://www.fiatforum.com/multipla/354429-door-handles.html
boilermansab
is the actual outer structure BROKEN or it's just no longer unlocking the door latch..??, :confused:
Charlie - Oxford
hi and thx for replay and sorry it took a while, new yrs partys n all lol.
ok so its the exterior door handle. the door would not close even though the handle was broken in half it still worked, but this day I pushed it down and the door still would not close and I was 40miles from home, so out of frustration I got the door handle and ripped it off, not thinking !!! but I could see the rod inside so with a long screwdriver I was able to push it down then I could close door, so all I have now is the cover of the door handle and nothing else as I pulled it all off out of anger :) seen as I cant find a door handle anywhere do you think I could use the rear one as its a pain getting through passenger side
