Titaniumviper
- Joined
- Apr 1, 2012
- Messages
- 24
- Points
- 9
Hi guys I'm the proud new owner of a 03 plate stilo jtd. I have a fair few problems I was hoping you could shed some *light on.
The gears are very stiff and ive noticed a oil leak from under the car.I'm assuming Its coming from the gear box hence the stiff gears. Is this a common fault on the stilos and an easy fix.
I've also been getting the the error message preheat fail. I've read on here to use fiat ecu scan and this says possible glow plug issue. Are these easy to change as I've done these before on my old car and were a total nightmare
I'm getting the infamous "airbag fault... Engine stop" message. I've read on here to use again *fiat ecu scan *however for some reason it's not scanning and giving me an error message so I was hoping someone on here could shed some light on this.
Finally I've also had the service due message come on which is intermittent,
And the 'loose connection' error message flash up a few times.
Had the car for less than 12 hours and it's already giving me a headache any help would be most appreciated.
