Hi there, I have a fiat punto 1.2, 8v engine, 2004. I just changed the timing belt, and the engine won't start. The exhaust will blow as I turn the ignition and the engine will constantly fail to start but it'll rotate the timing belt. I also smell petrol so I know the petrol's being pushed from the back to the front. I honestly don't know what it could be?
I believe the top bit (camshaft i think?) is aligned properly, as there was a white marker made previously that aligned the camshaft to the back of the engine block. So I've aligned that, although, for the phonic wheel, I don't know if that's aligned properly? How do I properly align / time these together? What else could be the possible cause the engines not starting?
The battery did die but I used those jump starter kits, so it can't be the battery. Is this just a situation where I take off the timing belt, I spin the phonic wheel a different position, put the timing belt back on and test the engine again and repeat these steps? OR is there a quicker way?
Any help would be welcomed, first time doing a timing belt
