Hi all.- :wave:
I have some problems fixing my dear Punto.- It was starting small, but grew big in a very short amount of time..
I thought an indicator problem would be a quick fix, but it seems to be pretty difficult to go around.
The problem started with fast blinking indicators ( twice the normal speed ). Then the exterior indicators stopped flashing, but instrument in dashboard indicated ok.
I disassembled the fuse box/body computer, showing lots of oxidation on the circuit board, leading to the conclusion, that something was fried.
I bought a donor computer from a similar Punto- 1.2, and hoped a swap would fix the indicator problem. But after thinking a little, i found that the body computer is NOT something you just swap, since the code for the ignition key is stored inside.
Problem is, that my kkl OBD cable is not talking with the body computer. Only Engine, airbag and ABS system.
Does anyone know what cable/adapter i need to get access to body functions with Multiecuscan? is it possible with the Bluetooth/wifi adapters from ebay?:
I have the original code card for the car, that seems to be essential to re-code the key.
In advance- thank you :worship:
