Styling New Marea Big Brakes
Neptuno
Curitiba, Brazil.
As promissed, see the new BIG BRAKES on my Marea Turbo.
A hell of lot work seating on the floor..I'm squared ehehehehe. :D
Some detaisl are:
Rear original disc dia = 240 changed to 290mm [}:)]
Front original disc dia = 284 changed to 320mm [}:)]
Low carbon casted disc.
Used DOT 4 Premium brake fluid. ( SHELL)
See on: http://neptuno.fotopic.net/c163094.html
Looks great.
Does it go...erm stop... any better? Like can you notice the difference or is it just knowing that they won't fade as bad and look great.
Dave
There is a notable difference:First couse the "level efect"(is that the correct term to use Dave?) and `second couse there is a gain of 20% in contact area....and for sure is a great point for tuning.
Neptuno
Hurri
U said and I tryed and it works normally
try it again please...http:\\neptuno.fotopic.net/c163094.html
Neptuno
Hi, thanks Neptuno, worked fine the second time around.
Those calipers look cool, I like.
But what's this about 'Lambo doors kit shop'?? On a Marea?
Hmmm... Interesting.
"Lambo"( scissor) doors is a kit to transform the way u open the doors for many different cars. There is a universal kit to convert the door hingles to open the doors like the Lamborguini car does.(that's wy Lambo)
I Know that there are many shops that sell this kit in UK but I have no ideia what the cost will be and how to bring to Brasil.
would u help me?
Neptuno
Hi, How much did those discs cost you (what make are they?) and where did you have the mounting bells made up to fit them? Also are they the standard calipers?
Cheers,
Ben.
Hi Ben
The total cost of the four rotors (disc and hub) and bells was close to 800.00 UK pounds (converted). They are made by a racing brake specialist called MultiBrakes in Brasil, that copy exactly the Wilwood racing brakes....Yeap i'm still using the standard calipers.
cheers
Neptuno
Olá Neptuno, meu nome é Alexandre de Porto Alegre. Você não gostaria de participar do grupo do marea e do brava do brasil? Tem um pessoal bem legal e muitos com MT. O grupo esta cadastrado no yahoo groups como [fiat_brava_e_marea].
Abraço
