- Joined
- Sep 1, 2017
- Messages
- 464
- Points
- 166
I saw on an electricians forum they don't use amperage rating for cable because its such a contentious subject. They just give the cross sectional area and you make up your own mind what it can carry. One electrician had installed a 9kw shower with 6mm2 cable, the building inspector wouldn't sign it off, so he had to rip it out and repace it with 10mm2. There was a long thread with opinion split on whether 6mm2 was ok or not. Things like how well ventilated the cable is to stop it overheating.
The cable ratings for domestic and commercial mains installations are set out in the Electrical Wiring Regulations tables, and they do take account of the differences between surface mounted cables and cables routed through conduit or contained in plaster etc. and length of cable runs. If a lekky can't understand that and work to the same standard that he should know is being applied by building regs, well...
But in Fiat's case, they make the van, and they publish the maximum design ratings for connections by converters. The rating for the conversion socket power cable is presumably determined by the chosen cable size, the fuse that Fiat decide to protect it with and protection of the BCM. Anyone who chooses to ignore that does so at their own risk, that of the vehicle warranty, or worse
