If it goes into gear easily with no grating and there is no slipping or weakness in the clutch, what you usually find with a new clutch is it starts to grip and the car pull away with the clutch pedal much nearer to the floor than with the old worn one.
I have noticed with certain makes of clutch, that they feel very soft in their action compared with the old days when a new clutch was fitted, but as long as it doesn't slip and goes into gears easily it should be OK.
I don't think you can adjust the clutch on your model, if it was grating I would suggest bleeding the clutch hydraulics, but you don't mention that.
Never the less if you don't feel happy with the car after the clutch was fitted I would go and speak to the garage, even if nothing is done, should it cause you a problem later then you can report that you did mention an issue to the garage.
