neon lights
neon lights
irish_bad_ass
DUBLIN
anyone know how to fix neon lights?
some of the lights on one of the strips are not working
go to hellfrauds/motorworld buy some more
bulbs sound like led tubes if u are proficient with a soldering iron u can strip the unit down remove damaged leds and solder in some new ones
LED neons can be repaired pretty easily. if you use a hair dryer to heat the black plastic end of the tube up it will melt the glue and slip off. do this both sides and then the whole circuit board will slide out . when you have this out you can simply replace the leds that are blown and then slide the tube back in and glue the ends on. i know because i had to do mine lol. il c if i still have the pics of when i did mine.
