capricorn1
- Joined
- Jun 10, 2017
- Messages
- 5
- Points
- 3
I messed up... lost its standard, in-situ, non electronic ign. key that started engine perfect; ; so i removed old lock and key assy. from steering column and fitted replacement;; only to discover in-situ. system lock and key had been previously modified to work without electronic code transmitting key,;;having fitted replacement lock and key assy., engine will now no longer start,... now suspect modification to have been column fitted close transmit/receive electronic chips....which has now become lost;;;; does anyone know how i can by-pass the electronic ignition system to start the engine (02 plate, diesel 1.9);;; or failing that, can i buy a suitable priced electronic column lock and key assy.
New to use forum.......any suggestions much appreciated.
thanks
thanks
