Technical Need help
Technical Need help
Cmeyers01
New jersey
Hi from New Jersey, I am having a issue where because I changed my battery all these different codes are popping up on the dash but when I run the ecu they do not appear , I even took it to a autoparts store to get it scanned and they said its just showing on the dash. We have tried driving it, disconnecting the battery everything under the moon. What can I do to get these codes to turn offf?
Hi :)
What codes are they??
A lot of readers only communicate with the motor :engine
ABS brakes... power steering.. etc
Are in the ' Body computer'... you need better kit to communicate with that
Tell us more :)
There is a lot, abs , parking not avaliable when its in park, drive mode unavailable when it can drive, 4 wheel drive unavailable, and bunch more
None of those are 'motor'
Search MultiECUScan
That may be your most cost effective way of addressing these errors
But being US based..
Try enquiring if There is a software common to the modern JEEP
It is a shared vehicle to the FIAT 500x
Remember - its the BODY you need to communicate with :)
Good luck..and do tell us what you find (y)
