General need help with my key
mintie
hi if my remote don't work but the key opens the doors and starts the car how can I get it sorted out I have no codes for the car at all if I can do it myself I will just wud need sum1 to tell me wot I would need to buy exactly many thanks
Before you can think on doing anything to setup remote for car you will need the Electronic 5 digit code only available from fiat expect £35 plus vat you may be lucky and get cheaper depends on dealer they do it over the counter..
Then like myself and many on here you will need Registered version of the multiscan software links above at start of Stilo page,,or if you know someone with the software come to agreement for setting up remote when using mutiscan... you have to set up all remotes again so make sure all remotes are available at time is only 5 minute process once you have code and software set up.
thanks can u tell me where to get the software from and wot exactly I wud need plz I will go and buy the code in the next few days vospers who I went to said the code wud be about £50
http://www.multiecuscan.net/Default.aspx
also you will need correct cables elm or other colour coded type.. have read of multiscan link and forum will give you idea
it may be worth calling any other local dealer for price on code mine was £40 if I remember..also you have not said where you are so if anyone already has the software and cables may be able to help you out..obviously the dealer can also do it for a price
yes I checked the key battery and its been tested at a garage for the IF bit and that's ok and im in Torbay in devon
hi mhowse I looked at the link and looked at the forum on there stil confused to what cable I wud need and which program to use as when I read it it said the multiscan don't support the remote reprogramming so I a little confused as if I know what one it is I need and what the cable is I will get 1 ordered and also get my key code from a dealer the only dealer I knw that does fiat is vospers and they r rip off ppl lol
yes as above the software is multi car software and does support remote programming but has to be the paid registered version you can not program remote with free trial version..I like others got second hand fiat remote key fob and used multiscan software to set remote, there are many elm cables about some work some need modifying if like above someone has tried and tested a cable be worth going for that as I had to modify mine ..
once you have cable is best to setup the free version first so you know it can connect to basic stuff first as you may need to setup Driver and microsoft netframework on laptop first but once you have it up and running is worth the ivestment if you plan keeping the car
thanks njnorcliffe so that link will be the cable I will need to help me reprogram my key when I get the key card ? and how much is the software I wud need to do this
thank u again njnorcliffe soon as I get my v5 document ill go to a deal to ask for the card as I just got the car bout 3 weeks ago and with winter like it is now I want a quick wat to get the doors open lol
Once you have the V5 document, you could contact the previous owner to ask if they have the card. :idea:
I have only had the Stilo for a couple of weeks so still awaiting the V5 from DVLA and no Fiat dealer near by (4 hours on a ferry and a 65 mile drive). I have various bits and pieces in the service history with my Stilo and along with many electrical problems, the remote locking doesn't work.
So, what does the key card look like?
help needed with multiscan and elm cable to the car
hi how do I use the multiscan and the elm cable where the heck do I put the cable in the car so I can reprogram my fiat stilo 1.9 key plz
Re: help needed with multiscan and elm cable to the car
The cable plugs into the middle socket in the top of the dashboard fuse box. The fuse box is located behind the drop down panel in front of the driver's (for RHD cars) right knee.
hi ty I fort it mite had been but did not want to push it in now all I got to do is work out how to set up multiscan so I can try it b4 I buy it
