Hi Guys,
Need help. with a 2015/16 2.3 euro 5 Ducato
I had to replace my ecu bsi key etc with perfect working units due to a tampered with ecu and drilled out dpf.
I replaced all parts ecu, bsi, dpf, reprogrammed keys etc. all working great van running amazing, however i have an issue.
My abs lights are on dashboard with code
Mes showing Dashboard instrument cluster error - u1706-87 Nfr Node missing absent - message
Engine Ecu - U1706-87 Can network (NCM-NFR) - missing message
The ABS module is not being seen on the network even after a proxy align
I have tried a proxy align changing abs to ASR in Mes which cleared constant abs warning lights however when i turn key to mar i get no abs lights showing at all.
Just errors above
The ABS ecu has old ecu vin number so not sure if a proxy align would fix this issue and update the vin with new ecu bsi module.
does this error point to a break in wiring. or does the abs need other things coded programmed etc.
Just errors above
