Hello everyone... this is my first thread here.... I'm from Egypt.. and I have a Turkish car called (Tofas - Sahin)
whatever.. this car runs with a fiat engine with the code ( 131CD5 4A)
lots of things are common between this car and the fiat 131...
anyways.. I have a problem with my engine...
The engine can't idle probably no mater what I do.. it keeps giving rich mixture... which results in black fumes in the exhaust of course... and low fuel economy...
I changed the upper fuel injection unit (containing the fuel injector and the fuel regulator) ... I changed the TPS, the lambda sensor, the crank shaft position sensor...
the coils and the spark plugs wires.. the fuel pump... nothing is working out...
it still give rich mix.....
I though it was a problem in my cylinder head.. (as I made grooves in it.. and I also replaced my 1.4 intake valves with the 1.6 intake valves) to gain main power... so I replaced welded the grooves and blasted the head,,, now I only have the 1.6 intake valves with power rings on them... and a ported intake for the cylinder head...
but it still making carbon layers on the spark plugs as long as it's idling..
It keeps idling probably for about 40 seconds.. and then starts to give rich mixture again.... Don't know what to do..
I even changed the ECU.. and still the same problem... The same porting and power rings are made in another engine which is similar to my engine and non of these problems are there.....
any advice???
any advice???
