S !sarah! New member Joined Jan 3, 2007 Messages 2 Points 1 Jan 3, 2007 #1 hey just wondering if my x reg fiat punto 1.2 has an immoboliser as standard n where it is? if any1 cud help i wud b very greatful lv sarah xxxx
A arseofbox Principality Retained :) Joined Jul 16, 2003 Messages 6,977 Points 1,078 Location Midlands Jan 3, 2007 #2 !sarah! said: hey just wondering if my x reg fiat punto 1.2 has an immoboliser as standard n where it is? if any1 cud help i wud b very greatful lv sarah xxxx Click to expand... It will have one yes. The main part of it is built into the electronics that control the engine. Not a seperate entity as such. The code box will be under the dash somewhere, although that alone wont tell you much.
OP OP S !sarah! New member Joined Jan 3, 2007 Messages 2 Points 1 Jan 3, 2007 #3 its only the standard 1242cc 3 door hatch so is that still correct?only asking for insurance purposes u see.thank you lv sarah xxx
fiatdownunder Established member Parked in the garage Written a guide Joined Feb 15, 2006 Messages 1,375 Points 201 Location Auckland Jan 4, 2007 #4 Hey Sarah, Your car definately has an immobiliser on it. all the mark 2 punto's came with them on.
M madmax127 New member Joined Dec 23, 2006 Messages 136 Points 36 Location colchester Jan 7, 2007 #5 yes u do its called a code system and is part of the bodycomputer which is situated behind and attached to the fuse box which can be replaced but youll need it to be proxialigned to work properly
