Technical Need a lot of help ???
Burnt Chips
Ive just purchased a 2003 lwb relay (1800 model) i think as ive only the slip of v5, with a 2.2 hdi engine,
it was purchased as a non runner (suspected head gasket) and the fact the header tank had a lineing of slick like the american coast kinda give that away, plus the fact it pumps out water faster than the firebrigade.
but i can`t for the life of me find a haynes or simular to get my timing marks,bolt torques etc and general assembley and dissassembly.
any pointers to where i can find 1,
and if thats not enough (its got the illuminated keylock lamp on the dash)
though the seller stated this wasnt there 3 months back when he last charged the battery, is there out i can do about this ? is it a replacement ecu ? as ive been offered a ecu /keys/locks and colum off a 2.8 relay is this compatable ? any help appreciated
You can download the manual in cd format or buy a cd of it on ebay.
Regarding the keylock lamp you say it pumps out water in which case you've seen it running? If its not running there is a switch on the firewall behind the battery try pressing it to see if your key light goes out. Otherwise you probably need to get the keys resynchronised to the ecu. Other possible problems are a broken / disconnected transponder antenna on the ignition switch.
Theres no reason to assume you need an ecu without a lot more diagnosis. The 2.8 ecu is of no use to you without getting it completely reprogrammed.
