So i have a 99 puntoSX mk1. I noticed that the engine temp was getting pretty hot and as i came to park the car it was past 3/4 on the temp gauge. I switched the car off but i then when went to turn the ignition to ON so i can at least put the windows up all the air vents blew out hot steam and water flooded the floor.
Now heres my theory on what happend. The water from the radiator must pass through the dashboard in order for the heater to function... so my guess is the pipe which the hot water travels through is cracked or has a leak at some joint hence causing the water to leak hence losing water from the radiator thus not cooling the engine enough. Since the engine got so hot it boiled the remaining water and shot it out threw the a/c vents.
Im i right? Anyone ever had any experience with this type of problem or is there someone who can point out to me where to look to find the problem? Im just looking for all the info i can get at the moment.
