dave_jayMK1
- Joined
- Feb 24, 2008
- Messages
- 6
- Points
- 2
that only happens if it has not been done properly...make sure the surface is clean and been sanded well enough.... then after about 2-3 coats of paint... make sure it is laquered...
most of the time it depends on what type of paint you use... the first one i had flaked in the bends of the surface (even after full preparation)... then i switched to a flexible spray, and since then no flakes....
hope this helps....
btw dont be put of by the idea, because if you make a mistake you can always remove the paint and try again...![]()
he didnt sand it...
someone mentioned fibreglassing it to me aswell, anyone know this method?
