I am the new owner of a 1971 500L. I’ve recently had my local classic garage fit a new engine and gearbox from a Polski 126.
The problem is that it keeps getting stuck in gear, initially second and now 4th. The Garage who did the replacement looked at the old 500 engine and found a couple of spacers between the flywheel and the clutch which they thought would solve the problem, it did for a short while but then it got stuck in 4th as you were driving along and the only way to release it was to stop the car and the engine.
Having looked at various 126/500 clutch replacement videos and manuals, I cannot see spacers between the clutch and flywheel, so I think the garage are barking up the wrong tree.
Also, and I an not sure if this is a problem or not, the whole set is very whiny, I’m not sure if that’s just the way it is with 126 engine and gearboxes, but it may be a smoking gun as to the problem. Any advice any one has would be greatly appreciated, tearing my hair out with this one, and not prepared to give it back to the garage until I have a proper solution.
