General multipla jtd help with turbo anyone?
chester
hi,
my multi has had a fault (engine management light on & fault code p0236 overboost valve) for 6 months or so now- tried everything!, replaced :
overboost valve, maf sensor, map sensor, egr valve, rubber tubing from
overboost sensor to turbo actuator.
main problem is as soon as car hits 3000 revs-fault comes on & car into limp mode.
bit the bullet & took it to garage, mechanic did some tests and said if it was his car he would start by removing turbo & clean the variable vanes with carb cleaner as he is convinced this is the problem. the garage will not do this due to warranty issues (their policy would be to replace turbo with new one), he knows my funds are already stretched, so he has at leat given me the heads up.
is there a guide to turbo removal on the multipla?, i have searched posts but cant seem to find one.
can anyone give me a step by step guide to removal and clean of the vanes?
ANY help at all is very welcome, so if anyone has any ideas.. please reply.
many thanks
mark :)
this looks like a very probable solution for under £41 delivered by
courier.
i searched loads of forums, sticking vanes on variable vane turbos is
extremely common after all, the symptoms are EXACTLY same as we both have- ultimately limp mode once ecu doesnt get fed the boost pressure its calling for, as the sticking vanes give reduced (or too much)
boost pressure.
this innotech turbo clean stuff seems to actualy work in the vast
majority of cases...& turbo doesnt even have to come off the car.
here is a guide/comments i have copied from other forums:
1. Remove engine undershield. (if fitted)
2. Unbolt exhaust from turbo (3 bolts) - don't lose the gasket unless you have a new one to replace it with.
3. The kit comes with a piece of card. Cut this out appropriately to the size of the exhaust inlet on the turbo. The card is used as a seal to stop the turbo cleaning solution from coming out. That means you can leave it in there to soak for a good long time (the kit recommends about 1 hour overall)
4. Using the tube provided in the kit, fill the turbo with the turbo cleaning solution, ensuring the card cut out is bolted in place using.
5. Leave it in to soak, then after 20 minutes or so move the actuator to help loosen up the crud on the vanes.
6. Give it another 40 - 50 minutes or so, then unbolt the card and catch all the solution in a suitable tray.
7. Next repeat steps 4-5, but this time use the "turbo clean 2" solution provided in the kit. (This is supposed to put some sort of protective layer on the vanes to help them resist carbon build up)
8. Empty out the remaining solution and put the turbo back together.
Also provided in the kit is a bottle of very strong fuel system/injector cleaner. This is to be put directly into the fuel filter. Remove the filter and empty out the diesel, then fill it with the injector cleaner. Put back together and fire her up! Give it a good 3 - 4 mile drive and that's it!
Glad you took my advice and you got the turbo spooling up how it should.
A mechanic that does this says:
I think I have saved 35+ Tdi owners over a £1000 each, after they had been quoted from main dealers to have there limp mode or under spooling turbo replaced. I would say the Innotec system has cured 35 out of 40 turbos I have used it on over the last 12 months. One turbo which it did not work on was a Ford Tdi 150pd, it still kept limping, so we striped the turbine down and cleaned the vnt direct with innotec and the car is running a treat 6 months on with over 180k on the clock.
The best way to use the cleaning kit is spend a lot of time working it into the turbo, spraying small amounts in at a time then work the VNT backward and forwards over a period of around 90mins
so there you go!!
i really do think this is the solution.
will order mine monday direct from innotech.
points to remember in using kit are: (stuff that sank in my head after reading tons of different stuff)
get car on ramps, the night before doing the job and spray loads of wd40
onto the exhaust bolts that hold exhaust to turbo & leave to soak in overnight.
next day remove bolts and seperate exhaust from turbo.
using the gasket that was between turbo & exhaust, make an exact template of the gasket shape out of 5mm ply or mdf (not cutting out centre hole)
use card template & one made out of ply/mdf onto studs on turbo where exhaust was & boly on nice & tight (if not tight seal the clean fluid will spill out) . through small hole in wood & card gasket (pre drilled) , insert can 1 tube into turbo- spray in small ammounts and move actuator rod up & down for up to 90 mins (use all can & work actuator lots),
after 90 mins remove gasket & catch all gunk coming out in a bowl.
replace gasket & spray in half of can number 2, then remove gasket & spray in remainder of can.
now replace original gasket & refit exhaust to turbo.
now remove fuel filter, empty out fuel and add the bottle of cleaner number 3 into filter and put back together.
take car off ramps & start up & go for a good run.
lots reccomend "italian tune( take car up to 4000 revs in 3rd gear to blast out any crudge a few times throughout journey.
effect should be immediate without limp mode & turbo responsiveness should actualy increase over following few weeks.
im optimistic :)
courier.
boost pressure.
so there you go!!
im optimistic :)
This is so well written and useful!
