plmotors32
- Joined
- Jan 5, 2012
- Messages
- 2
- Points
- 1
hi i have just bought a 04 plate turbo diesel multipla the problem is the heaters dont work or climate control. when i press buttons nothing lights up and no speed from fan on 1 2 3 4 upon closer inspection i saw the under passenger footwell what looks like where the fan might be 2 wires coming out and these have been connected to a relay and then back to a different switch one you can buy on the dash board. when you switch this switch on the heaters came on at a very fast speed but then went off.
1st. could the relay now be not working hence why the heaters wont work on this new switch.
2. what woukd be the reason to by pass the main heater control on the dash to this switch
i want to get it back to normal. i also noticed by this black box under footwell just below radio a black box of some sort with a harness cable this has been removed what is it for?
any help on testing this and getting it back to its normal working condition
cheers ian
cheers ian
