Can you get any pipe work for the multijet, turbo intake pipe im after, or is ther any tht may fit can be used etc
i take it u can do nothing with this engine after hours of crawling the net ive found nothing, is it all universal stuff u have to use
thers no pipework any wer, i asked for pipework not exhausts or inductions remaps, just pipework cheers for pointing out err nothing
not sure how your supposed to assume you are only talking about engine bay hoses/pipes/tubes.
theres a main reason why no one makes off the shelf silicone pipes for the mjet diesel,
diesel engines need to have FLURO LINED SILICONE HOSES ANYWHERE AFTER THE TURBO(which are pricey), as this stops the oil that is in the air from leeching through the silicone and eventually holing or rotting the pipe making it burst.
if you read the thread by alexh365, he has made a custom induction using normal universal silicone hoses, which is perfectly alright as the induction is on the inlet side of the turbo, therefore should be no oil to damage the silicone.
more on fluro lined hoses...
Fluorosilicone rubber is a material that has significantly greater chemical resistance than silicone. It is resistant to hydrocarbon fluids (petrol / diesel / oil) and solvents, and is typically used in applications where the temperature range of –60 to +225°C is required but where silicone is not resistant to the chemicals that the part will be exposed to.
thanks for clarifying this mate, i was unaware of tht so thanks, so is it not possible to change intercoolers on deisels without these pipes
yeah arch induction, tuning box, full custom stainless steel and custom high flow sports cat on monday, then winterwarmer then remap, like id just change an intercooler :S
