- Joined
- Jul 1, 2012
- Messages
- 426
- Points
- 226
I parked my 2005 MJ up for 2 weeks while I was away on holiday.
Since I've got back, it keeps on throwing up the high boost pressure fault code.
I thought at first it would be the normal thing, the wastegate actuator getting stuck.
However, the actuator moves perfectly freely. I've doused it in WD40, and worked it with a long lever bar several times, but the fault keeps on coming up.
Sometimes its when the engine is almost cold, it'll suddenly pop up and lose power......other times I can drive 50 miles no problem, then it'll suddenly happen.
Being that the actuator seems to be moving freely, is it possible that its the MAP sensor in the intake manifold that could be causing the issue?
Any ideas?
Any ideas?
