Earlofdavetona
I had my 2001 Multi MOT'd on Wednesday after it failed the test back in September and it failed again on Wednesday. (the gearbox went between then and now and I have only just got it back together and tested!)
Anyway, it failed the test in September on the handbrake cable and the rear seatbelt not retracting properly but that was it. I sorted those two bits out and changed the gearbox. (bearing in mind the car hasn't moved an inch since then) it failed again but this time on the offside track rod end. I bought a new one and have just gone to replace it and found NO movement in the balljoint at all, nothing, not even 1mm.
So, my problem is, do I: 1. Change the ball joint, take the car back and pay for the partial retest which is £27 or: 2. Do I leave the old balljoint on the car and argue with the test centre cos I have had a crow bar under the joint and its solid.
If I am right and I think I am, I think the test centre should pass the car cos there is nothing wrong with it and compensate me for the part I bought in error.
I'm also thinking of contacting VOSA to complain if I get nowhere.
Thoughts please anyone?
