There's a bunch of mods I'm planning to fit on my marea, namely:
1. Replace standard headlights with poly ones (BTW, did you know there were mareas with other lights than polyeliptical ones?).
I got a pair of UK lights and am going to open them, dismantle the lens and simply flip the diaphragm, in order to achieve "continental" light pattern. This has been proven to work on my friend's car.
However, I have one question - I've noticed that poly headlights have a rectangular-ish hole in the upper flat surface of the high beam reflector. My heads do not have such hole. Seems like factory made - what is it for? Any ideas? Could anyone go and check if you have it, too?
2. Install fogs.
I bought a pair of fogs + "cups" + auxiliary wire loom + switch panel. I will cut out holes in the bumper according to an outline on the inner surface of the bumber and add a relay behind the glove box.
Unfortunately, the switch panel I have comes from a Bravo and the connectors are different.
Did anyone make a custom switch? If yes - where did you place it?
3. Replace my AD182M (with custom AUX-in soldered to the mainboard) with AD182H + cable for AUX-in.
And my question is - will the cable work with H1?
Any comments and suggestions are welcome!
Cheers,
Tom
EDIT: And I forgot to mention - I am fitting a pair of gas springs to lift the bonnet. Bravo trunk lifters of exact size and power to lift the bonnet.
2. Install fogs.
Cheers,
Tom
