B byepunto New member Joined Feb 26, 2010 Messages 3 Points 1 Feb 26, 2010 #1 hi, I have a 1995 N reg punto and when the breaks are on, the indicators either flash like mad or fail to work! Helpful when i am trying to slow down to turn! Please could you let me know what is wrong. Thanks
OP OP B byepunto New member Joined Feb 26, 2010 Messages 3 Points 1 Feb 26, 2010 #2 and if anyone knows how this could be solved, that would be great to know It has been fixed before... just cant remember what was initially wrong as the garage did it and im a girl and useless with these things! :bang: is it the earth or a fuse?? (and where would you find these??!! xx
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Feb 26, 2010 #3 Definately an earth problem. behind each lamp cluster will be cables going to a bolt into the frame. Remove, abrade, refit and tighten, then cover with gease. Cheers SPD
OP OP B byepunto New member Joined Feb 26, 2010 Messages 3 Points 1 Feb 26, 2010 #4 Ohh you are an absolute STAR!! :worship: Thank you very much xxx
