General Mk2 C20XE Seicento - The Rebuild
Fingers..... What do you think...
There is a cardinal rule in engine building, "Don't mix up the bearing caps". The trick is to remember that the parts were originally bored in assembly, so the split line is never exactly on the center of the bore. One half circle will always be slightly different than the other, which is why the bore size changes when you swap bearing caps. Mix up the bearing caps and the crankshaft will sieze up when the bolts are tightened. The fix for this misadventure is not particuarly difficult, just takes a little head scratching, and it's not so tough with a 4-cylinder engine.
The easy way is to start with four con-rods on the work bench, label the rods 1-2-3-4 and the caps A-B-C-D respectively. Tighten the caps, measure the bores with a dial bore gauge, and record the numbers. Add the 4 various size bores together and divide by 4 to find the average. This number is the same for all Austin B-series engines (con-rods only) and should be spot on equal to the standard numbers shown in article CS-106
Then you take one rod with oversize bore (call it 1A) and one with undersize bore (call it 2B, swap the caps, tighten them down, and measure the bores again. You will find that the bore size is now different. When holding rod 1, the change of bore size (1A minus 1B will be equal to the difference of radius between cap A and cap B. When holding cap A, the change of bore size will be equal to the difference of radius between rod 1 and rod 2. You then know which rod and cap have greater radius and by how much. Repeat the exercise for 3C and 4D vs. 3D and 4C, and record all those bore sizes as well, before and after. So far you have only R&R'd the bearing caps once each.
Then take one of the largest caps and assemble it with one of the smallest rods, and vice versa. Ditto for all of the parts. Tighten the caps and measure all four bores again. If you got the head scratching and subtractions right you may have four identical bores on the first try, in which case you're done. If not, then you have already tried two of the four possible caps on #1 rod, and it wouldn't take long to try another one (or two) if you have to. When you get just one assembly with the correct bore the job gets lots easier as the number of permutations among the remaining 3x3 gets to be a lot less. Repeat for other parts if necessary. The object is to end up with four identical bores.
When you do get four identical bores, mark the rods and caps 1-2-3-4 on either side of the split line so they won't get mixed up again. If you don't have number stamps you can use a center punch to apply prick marks, 1 dimple for #1, 2 dimples for #2, etc.
There is another way to do this with engine in the car and no dial bore gauge. You only need to remove the oil pan and loosen the connecting rod caps so the crankshaft will turn freely. Label the rod caps A-B-C-D from front to back so you don't lose track of which is which. Tighten one rod cap only, and see if the crankshaft will still turn freely. If it does, label that rod cap "O" for oversize (even thought it might actually be perfect). If the crankshaft goes tight when the rod cap is snugged down, label the cap "U" for undersize. Then loosen the cap so the crank turns freely again. Repeat this exercise for all four rod caps. Make note of which "tight" cap is on which rod, as it surely does not belong on that rod.
You will most likely have two tight caps and two loose caps (law of chance and averages). I don't think it is geometrically possible to have 3 tight caps. Take any tight cap and swap it with any loose cap. Repeat single cap tightening and rotation testing again. Once again, make note of any "tight" cap and which rod, as it does not belong on that rod. By continuing to systematically swap a tight cap with a loose cap you will eventually end up with four loose caps, and the crankshaft will turn freely when all bolts are tightened.
This may or may not be the absolute optimum combination, but in most cases it is "close enough for a G-job", and a street engine will run happily ever after. With a little additional time and patience you can check all 4 journals with PlastiGage. If they are indeed all same clearance, you're done. Otherwise the results of the PlastiGage measurements will tell you which caps are tight and which are loose, and you can do a little more cap swapping to get better results. I have done this with a 4-cylinder engine a couple of times, taking 30 to 45 minutes each time. I had to do it with a 6-cylinder engine in situ once, taking more like 2 hours to get it right. I'm sure it would be possible with 8-cylinders (maybe all day), but for 8-cylinders it might be quicker to pull the pistons out and take the parts to the work bench to use the dial bore gauge.
_______________________________________________________
You can guess which section ive done.. The part started T here is another way to do this with engine in the car and no dial bore gauge. You only need to remove the oil pan and loosen the connecting rod caps so the crankshaft will turn freely. Label the rod caps A-B-C-D from front to back so you don't lose track of which is which. Tighten one rod cap only, and see if the crankshaft will still turn freely. If it does, label that rod cap "O" for oversize (even thought it might actually be perfect). If the crankshaft goes tight when the rod cap is snugged down, label the cap "U" for undersize. Then loosen the cap so the crank turns freely again. Repeat this exercise for all four rod caps. Make note of which "tight" cap is on which rod, as it surely does not belong on that rod.
Honestly does anyone think the plastiguage is worth the investment? if so... where can it be picked up cheap from, other than ebay?
Thinking im in no rush to get it together, and a few quid could save a rebuild...
That all looks sensible. FROST do it, but at twice the price of the best price I can find on eBay. A good factor might have some in stock. But for a fiver................... ;)
Be glad you've not got a 16 cylinder engine (and sorry you've not got a single!).
Lol...
Think il pop around the factors tomorrow... Gives me something to do... Had a think about it and it might be fine, but its worth double checking i guess...
May sound stupid, but could you not just put them back in, in the order they came off? Lable them up with a perm-marker/whiteboard pen and stick them with the bearings in seperate bags? :s
Did a few minor rebuilds at college a few years back and that worked fine, even when they got put on a engine rig and fired up. I seem to recall the engines we worked on being Vauxhall C20seh's.
Cheers
Tom
Well, today has been fun... not... Done a quick job for a customer this morning, and then spent the next 2 hours trying to track down the plastigage stuff.... Ive tried...
Halfords, Central Auto Supplies, RAE motor factors, Trinity Motors, Nuneaton Hose & Fittings, Round Tower Spares, Nuneaton Cylinder Rebores, & a machine shop in hinckley near the britania centre...
Still no putty!!!
Anyone local know where to get it from?
What about taking the rods back out again.. Removing the bearings and then torquing the caps to the rods... then measuring them with a vernier, getting the average over 4 and then mixing to get them all at the average value? Would that be the same as the putty idea?
Trying to make sence of that massive post i made the other day with the info off the net...
Ah well, you're a step ahead of me (or two or more). Still looking for a Cento which isn't full of rot and a garage with a roof that's not collapsing and electricity that works.
Lol... this ones being built in the great outdoors haha... Would love a garage, but its not really an option at the min...
Its hard to find a decent one tho!! I havent viewed this, but being 2002, i hope its fairly okay...
Its costing me £500 for the car, and it comes with mot till nov 2012 but no tax.. Im covering that at my own cost for £90 for 6 months!!! Cant believe the cost of tax to be honest, its a joke... although not as much as a joke as the insurance!!
Looked at the cost of standard insurance just to get it back and use it for a while prior to cutting up, and i am getting quotes for £480 with 6 years NCB & a clean licence!!! Think il just call Sky insurance and get the modified cover, as im sure i was paying £380-480 for it fully declaired with the 2.0 last time.
Got bored last night, so painted my sump... Pointless i know, and i normally moan at people doing it as its there to keep the oil as cool as possible... However id paid £8.95 on the hammerite & have loads left... lol...
Also here are two pics of the sei im hopefully collecting... Has a scratch down one side by the looks of it, and a blemish on the passenger side rear quarter...But unlike some ive seen, the wheel arches havent rotted away lol :p
Trying to work out why theres a sporting badge over the passenger side indicator lol... Although ive got a polishing mop, so that will be getting pulled off haha
Well.... Seems as if im collecting a sei either thurs or the weekend.. depending if my other half can get time off work to collect...
Meanwhile, ive done a breather mod to the cam cover of the XE...
The older high mileage engines have heavy breathing issue when used on the track, or driven hard. To cure this a lot of owners carry out a mod to their cam covers.. I know this engine didnt have any 'breathing' issues, however while its all apart, i might aswell do it.
You can buy a £110 kit from QED, however the cheaper (free) option is to do how i have done... Basically the original plate has been removed, and then cut to size, this then covers the breather exit, to prevent oil escaping out through the breather...
The mod prevents oil starvation/surge upon hard cornering, and removes kangarooing when letting off the throttle..
Not bad for a freebee :D
