Technical [mk1] Whistling noise dying after few minutes
machinogodzilla
Hi!
The car I've got a problem with is Punto 1.1 55S. When it's cold and I start it up it's ok until I start revving it. Then the whistling noise appears, and the more I rev the more intense the sound is. When the car is left on idle there is no whistling sound at all.
After I leave the car for a couple of minutes or drive it a little (it whistles on every gear and with the same characteristics) there is no more such sound until I turn the car off and leave to cool down. Then there is the same story.
I've read here about a loose cam belt but it doesn't sound like what you can sometimes hear on streets and you're sure it's a cam belt. This sounds somehow different.
Thanks for any help...
Cam belt tensioner bearing, best do the belt at the same time unless it's recent.
Hi!
Did you ever get the bottom of your issue with the whistling noise? I'm experiencing what sounds like a similar issue with my Punto and am looking for help.
Can you let me know how you got on?
Any input would be appreciated.
Cheers,
Dave
