A Aidey Guest May 12, 2004 #1 I've found a 1.8 engine that i need, on a 1998/99 is it a mk1 or 2 cheers aidey
J John Guest May 12, 2004 #2 If you can get an engine or chassie number the lads on here will be able to tell you Aidey. John.
P Paul R Guest May 12, 2004 #3 The engines are exactly the same, it doesnt matter! as far as i know the only engines that changed on the mark 2 was... 1.4----changed to---1.2 2.0-147-changed to---2.0-155 The 1.6 and 1.8 carried over, oh and the diesels change i believe to JTDs!(not sure on that as i dont care about diesels) Paul R
T Tom Guest May 12, 2004 #4 The 1,6 changed in a few ways, the gearbox is different and the ECU is different.
OP OP A Aidey Guest May 13, 2004 #5 Yeah but a mk2 1.8 is 155bhp, thing is mines knackered, and i've found a mk2 2 will it work with my ecu or will i have to replace the lot
A alan Guest May 13, 2004 #6 teh mk2 2.0 is 155bhp, not the mk2 1.8. The 1.8's were 115bhp. I don't know if there was an difference between the mk1 & mk2 1.8 though so i can't really help you!
P Paul R Guest May 13, 2004 #8 they both have 113bhp....they just badged it as 115 because it looks better then 113, and all the badges are nominals of 5! 80,100,115,155 etc
