General  mj cold start issue
stevehebburn
hebburn, south tyneside
hi,guys. i am having problems starting my 55 plate panda mj from cold.:confused: i have removed the glow plug connectors 1 at a time ,:rolleyes: and i am not getting any voltage using a 12v tester. :bang: where is the glow plug control unit located ? also is there a fuse or relay in the engine fuse box i need to check or replace. ( haynes manual is no help) cheers, steve.(y)
hi, thank you for the info (y)my panda mj does,nt have that type of fused battery connection:confused: had a quick look ( in this rain):mad: seems the glow plug controller is under the battery tray.;)will buy a replacement, see if that sorts it. cheers m8. steve (y)
Check there’s 12v going to the controller
There’s no point changing anything until you have checked feeds and earths
right hand connector
