Matt Hallw
- Joined
- Oct 22, 2021
- Messages
- 6
- Points
- 1
Hi, please can you help me?
I recently bought a Punto (2000 X reg) 1.2 16v elx from an old couple, which although a bit rough around the edges, is a low mileage example and looks mechanically solid.
It was running great in the 3 months I’ve owned the car, but suddenly started with a misfire 2 days ago. This misfire got bad really quickly. The misfire happens throughout the Rev range regardless of hot or cold engine temp. Engine also hunting on Tickover.
Added to this misfire, I am getting lots of weird electrical issues. These include:
Speedo needle jumping around.
Rev counter jumping around
Temp gauge jumping around
Warning lights lighting up
Power steering failing.
All issues resolve after switching off and on again, but soon return once I start driving again, especially the misfire.
Car taken to local garage. Unable to get a fault code from ecu. Will not connect to any of the machines or software the garage has, but will allow connection to other modules such as PAS.
Can anyone suggest what I should do next as mechanic is baffled other than suggesting an ecu fault.
Should I get a mobile ecu specialist to check ecu and perform a repair or replacement?
Anything else I should check first?
Given the weird electrical issues, I don’t believe this is anything to do with the coil pack, leads or plugs, but will change these as a matter of course once I have got to the bottom of the current problem. If I am wrong about this, please tell me.
The battery is fully charged, so not convinced that is an issue. Had the battery on an optomate charger which indicates good battery condition and holding charge.
I have read a couple of posts on dodgy earth cables. Could a bad earth cable cause the faults I’m am experiencing along with the misfire?
Any suggestions gratefully received.
