electricmice
Goldie Punto said:How much are these hoses ?
Do they also include the central connector.
Basically the hoses cost nothing. It's standard fuel hosing that you cut to length, the length being no more than around 5 cm each piece. Five of them meaning no more than about 30cm in length. Can't remember the diametre so you'll have to check. Check with yours before you cut them. Can't remember the diametre so you'll have to check. These are then attached to the fuel rail which is in 2 pieces, joined by the 5th bit of hosing in the middle. At manufacture Fiat sealed these hoses with collars that you have to destroy to get off. I've always replaced them with jubilee clips and they work fine. 5 pieces of pipe, 10 clips and some time to dismantle all the ancilliaries to get to them and you're done.
Matteo.
