Correctinternally (there's a rubber seal inside, which often perishes). If the car isn't reaching normal operating temperature within 2-3 miles
Also once it hits half way, it should sit there, you shouldn't ever see it dip down
Does the 1.1 Active have a temperature gauge?Also once it hits half way, it should sit there, you shouldn't ever see it dip down
Our Panda actually reaches normal running temperature slightly more quickly than the Ibiza or Scala did/do with their supposedly ultra efficient divided cooling systems (with two thermostats). When we bought her (Becky the Panda) she rarely got above the quarter mark and I just knew it was the thermostat. Bought a new one from S4p and she heated up much quicker and sits rock solid on the half way mark by the time I get out onto the main road - probably less than 2 miles?I'll give it a run later today. You said within 2-3 miles it should be at optimum temperature? Is it worth running all the heaters in the car at full as well to see how long it takes to heat up?
YesDoes the 1.1 Active have a temperature gauge?
OOPs, sorry about that. Does seem to be a bit of a lottery with thermostats though? Either you get a good one or you don't and all you can do to hedge your bets is go for a "known" make and trusted supplier. Do keep us informed won't you?I'll report back either today or tomorrow when I take the car out for a quick run.
If I was a betting man, I'd say it was the thermostat I changed last year. I'd picked it up from one of your recommended places, Jock, but hey, it can be a gamble.
I'm not going to discount the simpler things like "oh whoops - I didn't take X into consideration and actually I'm getting 300 miles to a tank and everything is around average"
Haha - I hope that didn't read like finger pointingOOPs, sorry about that. Does seem to be a bit of a lottery with thermostats though? Either you get a good one or you don't and all you can do to hedge your bets is go for a "known" make and trusted supplier. Do keep us informed won't you?
Absolutely not, no offence taken. Probably not good to "name and shame" on the open forum but feel free to PM me if you want to share the pain!Haha - I hope that didn't read like finger pointingI'll let you all know how it goes.
I try to use language very precisely. It let me down on that occasion, with potentially expensive consequences for others who followed my erroneous advice. I guess I'm old-fashioned, but if I'm wrong, I say so and fix it asap.Don't worry about it
My feelings too. Bonefish, I'm sure none of us thought for one moment that you were trying to mislead us. Don't feel bad about the post.Don't worry about it
I had a scare in my Golf on a bank holiday. I had to ask local cops for guidance to fuel. It went over 100 miles heavily laden with the light on and must still have had 3 litres left thank heaven.Its a 2.0TDI so I assume its just like any other VW TDI and is direct injection.
I can't say I have ever run out of fuel ever in my life
well not on my own cars, maybe when I worked in the trade where they keep a thimble full of fuel in cars but then there was always someone from the office with a can of petrol to get you going again.
Because I am quite rural if I am in a city, then I can have a good 20 - 30 mile trip home with only one fuel station on route that because it's rural can be stupidly expensive at it's worst last year one of them reached £2 a liter. so I try and fill up in town or once I am back home, but If I forget when leaving town the car can get very anxious on the trip back as 40miles left indicated on the tank, drops to about 20 miles of driving before the computer is showing zero miles left.
About par. Summer tyres give 5mpg more than winter ones!My wife gets about 40 mpg in an almost brand new 4x4, think it’s about 350 miles on a full tank, she does mainly short journeys ie about 20miles a day back and forward to her work.
Summer tyres give less mpg, are you sure it's that way roundAbout par. Summer tyres give 5mpg less than winter ones!
By all means touch the wheels near the centre where they bolt to the hub and compare with the others - fronts will usually be hotter than rears. If a brake is binding significantly you'll immediately feel the difference in heat. I'd be a little - or maybe a lot! - reluctant to touch the face of a brake rotor or even a drum as you might get badly burned. I note you do mention this but people need to be aware that they may very well be "super hot" so hot enough that even a brief touch will burn you. (depending on how the brakes have been used but can be very hot after even quite moderate braking) Guess how I know!@JoleePando I would also touch the wheels or brakes after a journey (brakes can be very hot).
If one is hotter than its opposite number, that tells you if a brake is binding.
Also check tyre pressures.
Even if you're doing short urban trips, 200 miles on a tank seems very low. I sometimes do a round trip of 350 miles on a tank in my 1.2
(35 litre tank = 7.7 gallons, so about 50mpg, which is what I've come to expect. My dash tells me I'm getting 60mpg+ average but it's lying.)
