Hi all i'm trying to save my beloved scudo 1.9d 2004 converted campervan. mileage is 140k.
About a month ago the engine chick ( MIL ) light came on, I tried to scan it with an OBD2 reader but there were no codes and erasing the non existent codes did not remove the engine light. The van was running perfectly so i ignored it. Just went for the MOT and they have changed the check points and now an engine light on is a automatic major fail. Taken it to 2 garages for diagnostics and both come back with the same thing that there are no error codes so nothing they can do.
I have had the van for 8 years and its been fantastically reliable and it breaks my heart to have to scrap it because of a little light bulb when still running great.
I'm reasonably competent with repairing cars and have good non-car electrical experience but i'm stumped as to how to proceed. Has any one else had this problem? Any advise on how to diagnose the issue? Could it be a short in wiring, faulty ECU, a sensor issues that instantly triggers the check engine light but does not give a code? I would be eternally grateful for any thoughts!
Some other information that might be useful. When the key is turned one click (dash light illuminated but car not started) the OBD reader indicates the MIL light is on (which it is) after starting the car the OBD reader says the MIL light is off (though it stays on).
I also have a small air leak in the fuel lines which i have not yet been able to remedy.
Thanks in advance
Kieran
Thanks in advance
Kieran
