General marea/brava
General marea/brava
Cars are the same except some body panels, as are the engines.
The difference you need to be looking for is whether its a mk 1 or 2
mk 1 has an alloy induction manifold and mk 2 has a plastic one.
There are small differences between mk1 and mk2 on the injectors as regards the holes in the injector and spray pattern. Although I believe they can be interchanged.
However identify your engine and identify the engine you are extracting from and swap like for like.
:yeahthat: Make sure its the same 1.6 16V engine and test the injectors your getting as its a common failure. If you can remove the injectors from a late model circa 00-52 you'll be in with a good chance of getting a decent set of injectors. You can use injectors from any 1.6 16V Marea, Brava and Bravo.
