Technical Marea 2.0 HLX MK2 OBD2 Location?
If its 155, no OBDII, if its 150 it should be under the dash somewhere, most likely below the drivers fusebox with a plastic cap.
Then it has 3pin connectors attached to the fusebox cover next to the right side front strut tower.
3-pin -> OBD and Multiecuscan is my suggestion if you want your own scanner.
Enginecode 182.B7 (same as bravo hgt mk2)?
The OBD engine was never on HGT so the code is 185.something.
