Jakewright29
- Joined
- Feb 3, 2021
- Messages
- 3
- Points
- 1
Hey guys hope someone can help. On the way home last night I came around a corner and hit a 2 foot deep flood (no warning signs) at 60mph.at first the car was OK, but 5 miles down the road it lost power and I was stuck in limp mode. I pulled over and I had a fault code P0697 sensor c circuit open. I reset the fault codes and it ran fine.
10 miles later I got home, turned engine off and the fog lights came on. I checked fault codes again and I had 6 more fault codes U1706, P0110 intake air temp sensor, P0087 fuel rail pressure low (twice), P0401 egr insufficient flow.
I went back out this morning to look at it properly but now it won't even crank over and there's a ticking noise that sounds like injectors running with engine off
