As promised to gordinir8 and IanEmery, but as I hope and expect will be considered useful by many other people, here is the "blueprint" for the tool.
The PDF image is a direct scan of the item, which if printed at A4 should be an exact template.
Fiat 500 Timing Tool Front by Peter Thompson, on Flickr
Fiat 500 Timing Tool Back by Peter Thompson, on Flickr
img034 by Peter Thompson, on Flickr
It's made of 2mm thick steel-plate and the two tubes are 30mm in length and have criss-crossed slots which are cut 8mm into the ends of the tubes. The diameter and wall thickness can be seen in the scan. I haven't tried it yet but it is evidenly very easy to use and should promote more accurate understanding of ignition timing.
LOOK OUT FOR THE VERSION WITH A RULER FOR SCALE WHICH SHOULD BE UPLOADED LATER IN THIS THREAD)
