Thanks to everyone for all the fantastic information on this forum!
I'm hoping that someone out there can give me some pointers on what to check next on my Fiat stilo 1.6 active.
The car developed an intermittent missfire about two weeks ago. It does not missfire all the time, only while accelerating hard or sometimes when pulling away from a junction. It does not seem to missfire under load (like pulling up a steep hill etc) and will not missfire at all if driven on minimal throttle.
The error codes that come up are "open circuit injector" errors (random selection of all four injectors) and "multiple missfire" errors. I feel it is very unlikely that all four injector coils have suddenly developed intermittent faults, so I am looking for another cause...
I have checked the injector coil resistances as per the Forum guide, and they all check out fine at around 15 Ohms. I have checked and cleaned the D81 plug several times, including opening the back of the plug/socket and given it a good spray of contact cleaner. I have fitted a new set of spark plugs for good measure. But none of this has improved the missfire at all.
Because it is still coming up with errors relating to a different injector coil each time, am I right in thinking that it is most likely a bad connection somewhere?
Is there any other connections that I could check? Or is there anything else that might give these symptoms?
I am trying to avoid taking it to the garage if possible as the 'Credit crunch' is biting hard at the moment.
