Ok I've spent a bit of time searching through FF and typed this up to give to the dealer next week during the first service. Any comments/feedback are most welcome
Reverse light
Problem: occasionally there is a delay between reversing and when the reverse light comes on, and sometimes it doesn’t even come on at all.
Please check: possible loose connection, or “sticky” switch control.
Reverse clank/grind
Problem: sometimes the car would not reverse, and instead makes a loud clank/grinding noise.
Please check:
“Check transmission, see handbook” error message
A “Check transmission, see handbook” error message + warning beep + gearbox warning light is randomly displayed (more often in recent weeks). This could happen at anytime, and usually goes away after several seconds.
NB: I have had this fault late last year and it turned out to be a faulty brake switch sending out a wrong signal.
Please check: all modules with examiner, possible faulty brake switch, and carry out any (software) updates where applicable.
“Tape A playing” message
Occasionally “Tape A playing” message will be displayed, but I don’t have a tape player! This usually goes away after either [1] the engine is switched off, then switched back on, or [2] ejecting the CD and putting it back in.
Please check: all modules with examiner and carry out any (software) updates where applicable.
Creaking when turning left
Problem: the front-right of the car creaks whenever the car engages into a left turn, and its more noticeable when it’s a hard/steep left turn. The creaking can also be heard with the car stationary and steering wheel turned anti-clockwise.
Please check: driver’s door lock/hinges, driver’s door rubber seals, welding on seat frame, cluster binnacle.
Juddering
Problem: after the car has been left cold for 1-2 days, the car judders when taking off from standstill in first gear to second gear. This applies to both auto and manual modes, and goes away after about 30 minutes of driving.
NB: I have had this investigated by your tech team several times and as yet no solution has been found.
Please check: clutch plates for (oil) contamination, possible faulty flywheel, and carry out re-calibration.
Reverse light
Reverse clank/grind
Please check:
Juddering
