Hi all
Im struggling with a fault with my grande punto sporting. Every morning when I set off on the daily school run, it seems to cut the turbo boost a bit then will go into a limp mode, where it refuses to rev beyond 3000 with no power at all.
Its also a bugger to start most of the time. It will randomly stop cranking and send the water temp gauge all the way up and throw up a overheating message. I've found if you let all the lights go out before you crank it, it will normally go.
I was told by its original owner that it required a new Maf so I got a bosch unit which seems to be working. When I check with multiecuscan it seems to be seeing 400mbar more air than expected at idle which turns into a fault. Its also complaining about the egr even though its still plugged In but I'm wondering if there's a wiring issue?
If you disconnect the battery for 20 mins, it will behave itself all day, which is a stopgap solution but id like to remedy it.
I must point out this car has a few mods done and has been dyno'd according to the previous owner who has inspected it and confirmed its all as it was when he had it.
The mods are a bigger hybrid turbo,and high flow injectors, decatted and dpf done as well,it has a straight through exhaust and the egr has been blanked off and a ramair cone filter has been fitted.
It made 232 bhp on the dyno but I can't verify as yet until I see the graphs but he says he's got them so I'll reserve judgment till I see them, but I will say its no slouch when it has warmed up.
Any thoughts at all would be greatly appreciated
Jay
Jay
