Technical LUMPY IDLE Panda 1.2 2004
tamworth
Hi guys I've got a panda 2004 1.2 petrol. It's pretty lumpy on idle and can here a missfire ar tailpipe .. it does not idle smooth but as soon as you rev it it seems to even out. Drives normally except when you rev it or put engine underload it sounds like there's a metal tapping knocking coming from the engine...
So far I've checked timing all good
Fitted new plugs, coil packs leads
Injectors, if I remove Injector 1 or 2 it bogs down for a second then back to lumpy.. remove 3 of 4 Injector and it runs worse as in barely runs.
All 4 plugs were looking good( no heavy carbon or wetness) but changed them anyway.
Mes comes up with no other fault other than lambda after cat...
Could that be the cause?
Any ideas?
pull a spark plug lead off the coil pack
start the car
make a note what the difference in running is
do the same one at a time for the other plug leads one jar a time
don't leave the car running too long with a lead disconnected a minute is fine
my guess one or more cylinders will make little difference these are the ones not firing properly
report back it will give us somewhere to. start
I would also remove and clean the throttle body and while its off check that the manifold isn't swimming in mayo. I have fitted catch cans in the breather line (c £15 off ebay) and find this has helped stop mayo building up in the manifold and gumming up the maf sensor. Occasional cleaning is still required but the difference in smoothe running, and power is substantial. on 2007 cars the maf may be elsewhere and cleaning may not be as straight forward as on my 2011 beast but a dirty maf does have a profound effect.
start the car
Removing the leads from 1 and 2 make little difference, the car compensates without them
. Removing 3 and 4( each 1 at a time) the car struggles to run...
Both 1 and 2 removed and it still runs but very lumpy.
No noticeable difference between 1 or 2 unplugged
No gunk in throttle body
dam
i would suspect there was a break in the cylinder head gasket between cyl 1 and cyl 2
before spending loads of time it would be a Good idea to do a compression test
lets see if I can find any other checks worth doing
but the symptom of less noticeable at higher revs would also fit
I will not call it yet. Give me half an hour to see if there is a direction to go
I've done a fair few cylinder head gaskets so it doesn't faze me... if it is just that I'd be happy...
Would that also give me a metallic knock on load acceleration/ or sudden rev from idle
here the symptoms when its really bad, depending how big the beak is you will get some are all
driving symptoms
Knocking noise when accelerating cold engine, clear up when hot
poor power at lower revs, bogs down then picks up, clears up when hot
stalls at junctions
erratic idle, revs rising and falling, sometimes a bit shaky at idle
judder on pulling off
misfire can be heard from the exhaust
poor fuel economy
occasionally need the coolant top up and occasionally a gurgling noise after you switch the engine off
driving symptoms
stalls at junctions
poor fuel economy
OK, so no coolant loss.
Yes knocks occasionally when cold
Erattic idle, no stalling
Yes can hear misfire at exhaust
I would do a compression test
Garage would do one for you
I bought on recently for around £10 on offer on Amizon. Not great but does the job
It’s one of those. You can spend a lot of time trying to eliminate everything else. Or do a quick test for what’s likely. And if it’s not move on.
Unfortunately most people don’t own a compression tester in there tool box.
I think it’s a wise move
Most garages will charge more than its cost
At the end of the day it can save so much time going round in circles.
Once bought you have it for future use and help friends.
The rubber cone adapter is fine for this. As long as someone is there to turn the key. You do have to push down hard. Can’t remember what my good cylinders were around 220 PSI I think
I'll use the screw in type. Should be better result than push in bit.. if its not level or seated correctly could get a false reading.
I'll post back tomoz with test results
Bingo.
Head gasket gone between cylinder 1 and 2.
I pre empted the issue and bought all the parts this morning..
40 mins for head off not too bad..
ditto
be carful ordering parts,
head gasket kits, there's more than one, euro 4 and euro 5 are different but most eBay list the same up to 2012
head bolts are all the same
I've bought from the supplier before...
It's now all back together and running sweet as a nut...
No splutter, no tapping..
Spot on..
Only other issue is an abs light on, says rear RH sensor but there is no abs, so I'm assuming it's a different ecu with higher spec..
I know punto 1.2 1999 to 2006 you can tell the ecu it's none abs but there is not a function for it on the Pandas.. ( using MES and in proxy alignment , you can set abs, gearbox type etc)
Probably not an issue this time, but idle speed that doesn't settle quickly or runs at higher revs yet stalls easily can be an air leak after the throttle body. The O2 sensors and ECU often hide the symptoms but it's easy to test with a spray of easy start around the inlet side of the engine.
Spot on..
Well done on sorting it
Strange there’s no ABS on a 1.2 ? I was under the impression only early 1.1 active were the only ones that didn’t have ABS?
A lot of the functions in multiECUscan are missing for the Pandas and what is available is often also year dependant Such as swapping the fog lights over is on the post 2012 but not earlier years. It’s a shame it is what it is. I miss short and long fuel trims.
