I'd welcome any ideas on this, car is Seicento 1108 (M3, MPI), new thermostat opens at 87 (it's brand new) but the radiator fan kicks in late at about 95 deg.C, is there a way I can lower this threshold ?
There doesn't seem to be a fan switch, I understand the ECU gets the engine temp. from the green sender as the only information the ECU has, please correct me if i'm wrong. The car runs fine but have had numerous overheating problems, now cured : new HG, new thermostat, radiator, pre-cat lambda sensor renewed, new green temp.sender, new spark plugs etc. I don't believe it has an airlock in the system it's been bled allright. Thanks @!
