Styling Lowering Kits Mk1
Coxyboy
Weston - Super - Mare
i want to lower my punto its on 17's, i want the springs and the shocks but i want the back lowered 20mm and the front lowered 40mm, there are no kits like this, does anyone know where you can mix or make up ur own kit, or even buy everything seperate???
cheers in advance
i want to lower the car 40mm at the front and 20mm at the back as it stands at the mo wid the stand springs and 17's wat kit would i need 1 at 40mm/20mm or 1 at 60mm/40mm as the sportings are 20mm lower neway, if i need thios 1 will it fit wid my 17's
cheers
cheers
your probably be ok, might need to cut down a few bolts, remove arch liners, but if your offset is right it should be ok lowered 60mm all round, so 40mm rear, 60 front should be fine.
well depends really lol, some quote figures for 55/60/75/85/90 some quote figures for sporting/gt so you will have to ask! but that kit i put up, should lower your car 20mm rear, 40mm front from as it is now :) but i cant be sure!
Is there a difference between suspension kits listed for a 55/60 and sporting/gt?, if not i can use either?? if so when i see a kit for a 55/60 that loweres 60mm/40mm, then i could still use it but it would only lower my sporting 40mm/20mm as it is already lowered 20mm standard??
thanks agin,
sorry if im being dum its confusing and im gunna order it soon and dnt want to cock it up!!!
where to get suspension kits
does ne 1 no where to get a decent make full suspension kit either 60mm/40mm for 55/60 models or 40mm/20mm for sporting /gt, cant find none neware.
cheers?
Re: where to get suspension kits
erm....pretty much ANYWHERE that sells suspension. Halfords, fastfiat.com, gazzella.cc, Hormann Motorsport...there are HUNDREDS of places on google that should be willing to let you part with your hard-earned in exchange for some stuff.
All punto suspension is bascially the same....so the kits for any variant will fit on any other variant.
