LOWERING ADVICE ON THE RAT2
R
ROBIN
Hi, all, wonder if any one can help me. i have been looking at getting the mighty rat2 lowered.
I want to go eibach but they seem only to make them for the 4cyl estate, now my thinking is just buy the 4cyl springs and fit them.
1: is this viable?
2: will it mean the front will sit lower than the rear?
3: is it safe?
4: will it handle anywhere as good?
cheers in advance
Robin
you be better off with the lowering springs off a coupe of hgt bravo wouldnt you?
I hear you, but they do make other springs for 20v estate, but i would rather have the eibachs, as for the bravo hgt i dunno if the rear are the same? also i could buy the 4 cyl set and the bravo hgt set and make me a set up as the rear is the same across the board i assume?
cheers
robin
im going to find out for you now mate....i have a man in the know!
mate they do a 1.9jtd yeah so that should be as heavy if not heavier than the 5pot, try them.....
just cut the coil dont be a wimp :)
She's a monster soon to be revealed :)
If they didnt want it stripping they shouldnt have used nuts and bolts :)
lower model springs wont fit on the front, they are a different size, nor will 20VT springs.
if you just want springs get the PI -40mm ones, they do a good job and i have them on my car even now.
when i upgrade i intend to get a Coupe KW Varient 2 coilover kit, although its a little expensive for cheap lowering at almost £1000 :D
when it comes to cutting springs i kinda sit on the fence with it, never have done myself but if done correctly i cant see a problem with it.
if you go lower than -40mm you might find tyres catch the arch, mine do now i have spacers for the brembo's
Ry
Coupe has slightly softer springs at the back.
Have KW finally released a kit where you can adjust the rear ride height like the FK kit?
F
7K
F1-ANG
F
E
889
E
C
498
ChrisKnottIns
C
