Basics first!
Check that your oil and water are ok and that there is none of one where the other should be. Just a quick check to make sure the hg isn't leaking again!
Next go round the engine bay and check that everything is plugged in properly. Pull each connecter apart and put it back together. Then check that your plugs are all in and properly tightened. Then check that all your plug leads are properly snapped on at both ends. Hopefully one of those will sort it out! It's so easy to miss a connector when you put an engine back together after major surgery like a hg change! Check that all the earths are secure and use a multimeter to make sure they've got a good electrical connection.
Replace your plugs and leads (or borrow someone elses that are known good if possible, that way if it's not the problem you haven't wasted money).
If that doesn't sort it then have a look at the coil packs. They have a habit of failing so that they only cause problems when under heavy demand, for example when accelerating. This is often the cause of the problem you've described!
If none of these help, then you need to start looking at sensors. The lambda is most likely, though unusual. If you have a mate with access to proper diagnostic kit then that should tell you whether the sensors are performing correctly. If not you can buy a lead and get freeware software that allows you to plug any old computer in to your car and read the parameters yourself. The software is available
HERE and the leads are about £10 off eBay, look for a "k-line (VagCom) USB" or "ELM 327 v1.3 (or later) USB" interface cable.
I know there's a lot of info there, but like I say, do the basics first. Most of the time that'll cure it without expensive diagnostics and/or parts replacement. A set of plugs leads will cost you maybe £20, a replacement coil pack should be round the £20 from eBay, a bit more from your local parts merchant. A lambda sensor, or a temp sensor, by comparison will set you back around £50 to £60, and that's assuming you are confident with doing the work yourself!
