one of these two (the things with springs) has popped off
Thanks for this post, it has helped!
My gears have just gone, but the two linkage arms with springs are still connected, they have not popped off, but the gear stick is still loose and not engaging any of the gears correctly.
I can move the top linkage arm left and right - with the gear stick moving and clicking into gear but the stick is still loose.
Any help greatly appreciated.
As its been wiggled - are the cables moving on the gearbox?
works case is the cables have snapped - and its a swap from a scrap vehicles to get you on the road cheap
Ziggy
sit someone in the car and get them to wiggle the gear stick from left to right, if you see the movement in the engine bay then get them to change between 1st and 2nd gear (forwards and backwards throw of the gear stick) which ever cable you see movement in then its the other cable which is knackered, alternatively you can pop the linkages off at the gearbox end and pull them out the one that comes out in your hand is the knackered one.
You should always listen to that Punto How To fellow he seems to know his stuff
