Technical loose connection on 2.4
ok, bought a new sensor for £21, i installed it in less than one minute, and been ok ever since. NO MORE LOOSE CONNECTION ERROR
i bench tested the old one, and it seemed to work when cold, so i can only assume it was breaking down under heat.
so if you get a loose connectoin error, invest in a £21 crank sensor. and if you want pictures of its location then PM me, i took plenty of pics while i was under there!
GUIDE... ;) :p
Well if you must know then look down and you will see what happened!!
Dont look down if youre a little squemish. And MODS please feel free to remove this pic at any time if its un appropriate.
I had a bit of a fight with a sharp sheet of 1mm galv in work, and as you can tell i obviously lost. I think i done it the day after i fixed the crank sensor. lol
